Amp Meter and Harness
Hey, I need to know how to hook up a aftermarket AMP meter out of the 3 gauge cluster? I have a 1971 harness in my ford truck and I also need master diagram of the 1971 harness for a ford truck I need it asap! Thanks
- 72hiboy4x4
re: Amp Meter and Harness
uumm, did you try the tech and tutorials page?
here is one for a '72. should be the same or close.
http://www.fordification.com/images/sch ... _quick.jpg
here is the rest of them, if that one doesn't work.
http://www.fordification.com/wiring.htm
