Hemmi's 1971 CS
- Manny
Re: Hemmi's 1971 CS
Man watching this on for sure nice clean truck and good work. love the exhaust it looks almost like stock LOVE IT!!!
The Junk that hangs around
1974 Bronco 302 3 speed
1984 bronco 302 c6 35's
1994 F350 7.3 5spd dually.
- Hemmi06
Re: Hemmi's 1971 CS
Thanks "terry1167" and "Manny" for the comments...
Doing a little here and there as money allows this site is what keeps me thinking. I like to share as people may have the same idea and want some options.
1971 F250 Camper Special
360cu with RV cam and 4v Carb
- Hemmi06
Re: Hemmi's 1971 CS
Rejetted the Carb today. After checking the plugs I replace recently they were still white after 200 miles. I believe she is running a bit lean. No melting of the plugs just clean white. Went from a 65 jet to a 67 jet on the Holley and will update with any news.
- Hemmi06
Re: Hemmi's 1971 CS
Re: Hemmi's 1971 CS
I liked your videos. Thanks for sharing. I need to do a video of a walk around!
'72 F250,390,C6,76K Sport Custom, Camper Special "Ole Blu"
'90 F250,460,48K XLT Lariat, Supercab
'88 Lincoln Mark VII LSC, 5.0 H.O.original, was daily driver, now retired
'97 Lincoln Town Car-Cartier,73K, 4.6, fact. dual exhaust,mint/original-Last Big Towncar
'05 GMC Denali XL,6.0 Vortec-for the wife & kids
'02 Cadillac DHS,4.6 Northstar-daily driver
'73 Great Divide 22' travel trailer,restored to original
'79 Mitchell 11' "Challenger XL" cabover camper-restored to original
'88 Lance 11'3" LC 780 cabover-current project
- Hemmi06
Re: Hemmi's 1971 CS
So I did a full shake down last week. Camping trip 400+ miles round trip pulling a travel trailer (5500lbs) and a bed full of stuff (1000lbs). 90 Degrees outside and in the flatlands all was good, tranny holding at 240 degrees and water temp 210.
Then came the full court press 4500 foot elevation gain in 10 miles. Temps climbed to 235 water and 270 transmission. Had to take a break at 3.3, 5.7 and 8 miles to let things cool down.
I learned a few things about my Ford F250 Camper Special: It is a great truck and handles quite well for its age actually rides better with a load.
Notes: If you have an electric fan make sure you can have it run with the ignition off, this will keep you from smoking your coil and ignition parts while you attempt to cool your truck down. I had to replace the coil when I got home because the overheating (ignition on) caused oil to seep from the coil and a weak spark. Also this did not make my Pertronix Igniter very happy with the heat and leaving the key on.
It got so bad but I was fine on the return trip in the flatlands. There is a small hill before my house (1000ft) and I had to drive around it at 35MPH because of the above mentioned items.
Did not burn one ounce of oil and never overheated (boilover)!! I do believe my water to antifreeze is off (I have too much antifreeze) I think if I fix this it may run cooler.....
Can anyone mention a truck of newer years that can limp home on 6 cylinders pulling a ton of weight? It would be a AAA candidate!!!! I just wanted to share!!!
- Hemmi06
Re: Hemmi's 1971 CS
Took her for a trip to the Good Guys "Get Together 2011" Pleasanton, CA. The only bump I saw inside was mine. There were a few in the for sale area that were in pretty bad shape. As my buddy said, "These are turds"
Nothing importnat to note on the project.
I am fighting over heating coil and coil manufacture defects... More to come when I get a solution I am happy with.
- Manny
Re: Hemmi's 1971 CS
Hey Hemmi glad to know your shakedown went okay I have fried a coil myself with the key on problem. I don't think your antifreeze is bad off 50/50 under any pressure will hold 230f without much trouble That 270 outta the auto trans woulda freaked me out though.
Oh and yes these trucks ride way better loaded!!!!! Still looking good.
- Hemmi06
Re: Hemmi's 1971 CS
Thanks again for the positive thought Manny!!
I may be going back to a stock output coil and using the resitor wire setup. I do not think Pertronix coils are the greatest. They can't handle the heat and 13.7 volts of power from the 3G alternator upgrade.
Updates to come.
Did take it for a spin to the Dentist today.
Made a painful day a bit more enjoyable!!
Updates to come.
- timmytim
Re: Hemmi's 1971 CS
cool truck!! great job on upgrades tooo
buy'em dirty sale'em clean
get more money for the same
machine.....
My 1967 bump: http://www.fordification.com/forum/view ... 09#p668209
My 1970 Bump: http://www.fordification.com/forum/view ... 16&t=50726
- timmytim
Re: Hemmi's 1971 CS
[quote="Hemmi06"]
I am doing the same alt upgrade and wondered if you know what size bolt is used on the adjusting belt bracket? The one in your pic
3G Upgrade
machine.....
- Hemmi06
Re: Hemmi's 1971 CS
timmytim wrote:Hemmi06 wrote:3G Upgrade![]()
I used the bolt from the original alternator and tapped new treads in the 3G...
- FoPAR
Re: Hemmi's 1971 CS
nice truck and nice up grades
"FoPar" because I love Fords and Mopars so just call me FoPar...
- timmytim
Re: Hemmi's 1971 CS
Ok thanks. That's what I was plannin to do
machine.....
- Hemmi06
Re: Hemmi's 1971 CS
I had a request for my exhaust setup and I see that some pictures were gone. I went and updated all my pictures for reference. Happy Holidays to ALL!!!
