why am I not charging? (updated 11/18)
re: why am I not charging? (updated 11/18)
I'm not real sure honestly. the purple wire that is supposedly resistive on the stock harness from the ignition switch, doesn't get constant power, which I believe it should. The white wire from the kit I bought, is constant power, so I don't know if it should or shouldn't be.
I also can't find my "dummy voltage" light. All I found is the brake warning light, which mounts on the dash below the instrument panel, beside the ignition and stuff.
Where am I supposed to be looking for this "dummy light" if I even have one. I have an "ALT" gauge that reads D to C, which I assume is dead and charge. im still hunting, not gunna give up on it, just tired of this crap.
The idiot light acts the same as the resistance wire as the light is wired in series (power from switch goes on one wire and the other wire goes to the voltage regulator)
A light like this should work http://www.painlessperformance.com/webc ... ield=80208 I've seen them called Pilot lights, you just need one that has single element and 2 wires (housing is not the ground). I've seen lots of LED lights like this but I'm not %100 sure if they will work or not, they are easy to find and cheep so you could try one.
Other thing would be to go to Radio Shack and get a resistor and wire it in line (they might have a light there also…) I would wire the resistor out on the fender well close to the Voltage Regulator.
Anything over 560 ohms should of done it, so the 560 or 640 should have worked... You might have killed the Voltage Regulator from before or you have some other problem.
On this "exciter wire" it should be hot all the time the key is on (run) for the other question you had...
