why am I not charging? (updated 11/18)
layedout72
Post by layedout72 »
Alright, I have all new cables, new battery (well....used but checked by autozone and sold as new/used), and my alt checked out good.
Why am I not getting a charge? I had it up to like 11.7 running....yay how exciting, right? lol Should it not jump up to 13.4 when running? It's the same running as it is not cranked. Also, the voltage regulator is new.
Whats not right?
ima71 trucks are older
Post by ima71 trucks are older »
14.4 or close to it.
how old it the voltage regulator or more important the voltage regulator conector. The connector is about $4. Also make the sure the engine is grounded the the firewalll and frame. Motormounts make bad grounds.
68 F100 soon to be on an 80's 4x4 frame and 300-4spd
69 F100 300-4spd
78 F150 300-3spdOD
layedout72
The battery is grounded on the core support and the motor is grounded on the firewall. I need to get a cable for a frame ground but I think I am okay as it runs fine and all, lights work, that kinda stuff. Voltage regulator is brand new, and the connectors are just little slide on connectors, it's not the stock style connector. they are getting a good connection.
would somewhere like autozone have the plug for the regulator?
QC
Post by QC »
The battery should ground to the engine block.
69 F-100 Ranger 302
layedout72
hmm....never had it like that before...but I will see if I can do that...
rjewkes
Post by rjewkes »
yup should be a hole up under the area around the alternator.
also mine charges fine with it bolted to the alternator bracket.
I couldn't find my hole as it may have the bolt busted off in it.
FORDification
Site & Forum Admin
Site & Forum Admin
re: why am I not charging?
Post by FORDification »
Right...it should always be grounded to the block. Not the frame and not a body panel. Electricity doesn't travel through rubber very well, and that's exactly what you're asking it to do, by having to travel through rubber radiator support bushings and engine bushings.
lightning_msd
Post by lightning_msd »
my farad says everytime i start it it jumps to 14.5 - 15
basketcase0302
Post by basketcase0302 »
You do have the voltage regulator mounted don't you?
If I'm not mistaken it too has to ground.
I'd check the voltage right at the alternator first, (sounds to me like it's not putting out). Should have way over the 11.4 like you said for sure.
Basketcase
layedout72
well, i will buy another cable and ground off to the block. and it should go batt to block, block to body, body to frame? is that right?
yes . thats right. you should have a ground from the lower valance to the frame and front bumper on the pasenger side i think if its still there. if not then that would be a good place to put one back.
layedout72
the purple wire that runs from the ignition switch to the I post on the regulator, and off to I believe the ammeter, I have been told I don't need it, but what exactly was it?
I have an "alt exciter" wire that I was told to hook to the I post, but I don't know if that's right or not...
Could this be part of my charging problem?
spartman
Post by spartman »
FORDification
Site & Forum Admin
Site & Forum Admin
If a truck is equipped with an ammeter, the wires to it are yellow...and both of them are shunted off the cable which extends between the starter solenoid and the alternator.
The purple wire is a resistance wire, and ties into the green/red wire which extends from the voltage regulator to the instrument panel. (See this diagram.)
layedout72
Re: re: why am I not charging?
FORDification wrote:If a truck is equipped with an ammeter, the wires to it are yellow...and both of them are shunted off the cable which extends between the starter solenoid and the alternator.
okay, so i need to use the purple wire, and run it straight to the I post on the regulator? That's what i'm getting from the link spartman posted...
