ignition
omegaman
Re: ignition
Post by omegaman »
Sounds like power to the ignition module is dropping off when your cranking. Probably hooked it to the wrong wire. should be easy to fix. wipers and radio drop off during crank so your probably hooked to something like that. put that **** back in way better than points. What engine do you have?
Orange Beezy
Re: ignition
Post by Orange Beezy »
When you say bypassed, would I have to run a new wire, if so what gauge, and does the resistor wire need to be removed?
Kurt Combs wrote:Does the new electronic system require a full 12 volts? If so did you bypass the resistor wire from the ignition switch?
I WILL KEEP MY GUNS<MY FREEDOM AND MY MONEY!
YOU CAN KEEP THE "CHANGE"!
1968 FORD F250 CC LWB 390 C6 w/1972 front disc brakes
1965 Ford Fastback 2+2 (SOLD)
omegaman
Re: ignition
Post by omegaman »
Orange Beezy wrote:When you say bypassed, would I have to run a new wire, if so what gauge, and does the resistor wire need to be removed?
If the electronic system requires full 12 volts the stock wire can either be removed and replaced with a normal wire or you can just run another wire along side it but thats kinda sloppy.
Drake
Re: ignition
Post by Drake »
The po of my truck installed a 73 460 with a duraspark ignition and actually got away with leaving the resistor wire intact. Stumbled upon the 6.8 volts to the coil by accident and thought it was strange that it wasn't 12. Truck still ran fine. Installing MSD package soon so will change it all up then.
