Random cut wires
Re: Random cut wires
so im also being told the two green/yellow to one red is supposed to be going to my fuel guage switch???? i only know of one and thats on the floor next to my seat.
- colnago
My truck has a switch on the dash, too. As I understand, the floor switch is just for the plumbing of the fuel system, and the dash switch is just connecting the fuel senders to the dash gauge.
Joseph
Joseph
This is the only thing that i dont know so far what its supposed to go to thats on my dash
and all it does is go outside the truck.not connceted to anything either
ok so went back to my truck and followed the wire that came from my fuel tank too the dash.from the picture you can see, the arrow without txt from what i was able to follow is the same wire from the fuel tank after it goes through elctrical tape.
however it is cut here.
now what i am wondering now is the green/yellow wires are supposed to be fuse to courtesy lamp switch, what would happen if i was to connect the cut wire with the two green/yellow to single red wire? dont want to melt or start a fire
UPDATE the wire that is cut that i thought was from the fuel tank actually goes outside.....
Alright so i was just checking wires with a circuit tester that lights up and i grounded the clip and touched this wire
and what sounded like the starter spun????!!!!
dont have a manual choke, so that means i can toss it then?
Holy Crap i feel like a Big Dumb A$$$, i didnt realize that the PO installed a MOO Horn LMAO
