Hi guys! have a quick question, when removing the wiring harness from the back of the Ignition switch, are there any clips holding it or can I just wiggle it towards the rear?
Ron
Ignition switch harness
- Ron_Hall
1971 F100 SWB 390 FE - bored.030 over
Edelbrock Performer - Holley 600 CFI
Stock heads with some porting - Sanderson FF427 Headers
C6 with stock converter - 3.25 rear end gears
One owner...
One owner...
Re: Ignition switch harness
1970 F250 460 C6 - Project - Currently not running.
1999 Dodge Durango SLT 4 x 4 5.9 Magnum -not running.
1999 Toyota Corolla - Daily Driver.
https://fordification.com/forum/app.php ... y/album/43
- Ron_Hall
One owner...
One owner...
- MadMike
Unscrew the switch from the dash, pull it down as much as you can, wear some gloves and squeeze the two tabs and wiggle-wiggle-wiggle-wiggle the begesus out of it. If it hasn't been off in quite some time it will be a mother to get off.
-Michael
My '70 uses the spade lug type of switch, but has no clips to hold the connector in place.
No bait, was just telling you to wiggle it(just a little bit).Ron_Hall wrote:Thanks for the click bait!!!DisneysPatB wrote:https://www.youtube.com/watch?v=DN2bQrCW2iA![]()
- Ron_Hall
Got it, thanks...DisneysPatB wrote:No bait, was just telling you to wiggle it(just a little bit).Ron_Hall wrote:Thanks for the click bait!!!DisneysPatB wrote:https://www.youtube.com/watch?v=DN2bQrCW2iA![]()
One owner...
One owner...
- Ron_Hall
No tabs... just wiggle-wiggle-wiggle-wiggleMadMike wrote:Unscrew the switch from the dash, pull it down as much as you can, wear some gloves and squeeze the two tabs and wiggle-wiggle-wiggle-wiggle the begesus out of it. If it hasn't been off in quite some time it will be a mother to get off.
One owner...
One owner...
