72 F100 Coyote Build
Re: 72 F100 Coyote Build
Beautiful wheels! What size and backspacing did you go with?
Barry
Barry
Thanks! 20x10. 6 3/8 front. 6 back
What size tire are you thinking in the front? 275?
Barry
Barry
255/40ZR20 front, 295/35ZR20 rear
- hfdco4
Nice work.
Paul
FE390PC
1970 F250 4x4
2016 F150 4x4 2.7 ECO
Gone 1988, 1989 & 1991 Broncs
1970 F250 4x4
Exhaust done.
- poke em
Looking great. Can you post a photo from the rear of the truck showing what the exhaust looks like? From several feet back, so you can see how it looks from under the diff? I just dumped mine in front of the diff, but the drone is annoying. I insulated the cab very well but the bed floor reverberates like crazy.
Are you going to use a sway bar?
I'll take a pic when I'm back at the shop. Yes, I plan to run a sway bar.
Pic from a little further back. There will be a panel in the back that I'll flush in some exhaust tips into.
- sport71
- hfdco4
All I can say is " AWESOME".
Paul
FE390PC
1970 F250 4x4
1970 F250 4x4
What exhaust headers and fuel cell/system did you use?
Used the factory headers that come with it. The rest of the exhaust was custom by a local shop that I use. The fuel system is all AN stuff. Aero motive pump. It's overkill for this setup but I like to have a solid base future upgradesdiznasty wrote:What exhaust headers and fuel cell/system did you use?
Do you remember what size tank and brand? I was laying out a very similar system.crestronwizard wrote:Used the factory headers that come with it. The rest of the exhaust was custom by a local shop that I use. The fuel system is all AN stuff. Aero motive pump. It's overkill for this setup but I like to have a solid base future upgradesdiznasty wrote:What exhaust headers and fuel cell/system did you use?
Tank was from Summit. It came with the pump installed. I'll be back at the shop Monday and can measure.
