1967 heater wiring relay high/low fan
1967 ford 428
Post by 1967 ford 428 »
Hey everyone... does anyone know where I can get a heater relay that adjusts the high/low setting? it goes in-line from the power source to the hot lead of the heater. Thanks for any help...
https://www.youtube.com/watch?v=a44-iTsIgnM
this is my current build... thank you for the help...
Mach428
Re: 1967 heater wiring relay high/low fan
Post by Mach428 »
That should be built into the switch. Does your switch have a four-pin connector?
