Under hood engine compartment lamp staying on.
Pat Crash
Post by Pat Crash »
So, 3 times this month, I have noticed that my engine compartment lamp is not shutting off after fully closing the hood. One time it even drained the battery after staying on all night. Sometimes, I am able to swing the hood back and forth to get it to shut off, but the problem appears to be worsening. Is there any easy fix or a replacement part for this old unit?
1971 Ford F100 Ranger XLT Long Bed — 360 with C6 Automatic — 9" with 3.00 Gear Ratio
Re: Under hood engine compartment lamp staying on.
I was told they have a mercury switch in them. They have to sit at the correct angle to work. On or off. You could try adjusting it. A replacement would have to come from a newer truck i would think.
pops53
Post by pops53 »
Yep...they are controlled by a mercury switch usually mounted on the top of the light. I don't think there is any adjustment to them. If you can find a replacement do Mine worked for years and now it wont come on. You may have to replace the whole light.
Pat Crash
Post by Pat Crash »
Hated to do it, but for now, I just removed the light bulb so it doesn't drain the battery when it the issue acts up. I'll be keeping an eye out for a replacement.
