new alternator not charging batery
Blue1971FordTruck
Post by Blue1971FordTruck »
ok so the new alternator wont charge the battery either
all of this is new
1)alternator
2)voltage regulator
3)solenoid
4)plugs
5)wires
6)battery
any help or comments is welcome.
and try to dumb it down for me and explain it as well as you can im 16 years old and really need all the help i can get :fr: :? :? :? :? :?
Nitekruizer
Re: new alternator not charging batery
Post by Nitekruizer »
First of all, how do you know it's not charging? Are you going by the gauge in the truck, if it has one? The AMP
gauge in the dash may not be working, but the charging system could be working fine. The AMP gauges are protected by fuses located under the hood and if one of the fuses is blown the gauge will not work.
First thing I would do would be to measure the voltage at the battery with the engine idling. With all lights and accessories off you should have anywhere between 13 - 14.7 volts at the battery. If not, then re-check all connections and grounds, including battery terminals, to make sure they're tight. Make sure that the voltage regulator is grounded. It's okay to connect your electric choke to the Stator (STA) terminal of the alternator. Doing that wouldn't cause your charging system to not work. Also check your wiring harness for splices, frayed or worn insulation, etc. Here are a couple of wiring diagrams for the charging system, depending on whether your truck has an ALT light or an AMP gauge.
Check that all of these wires are connected to their correct locations. The most likely place where the wires may have been mixed up would be between or at the alternator and regulator. "Orange-Blue" means orange wire with blue stripe, "White-Black" means white wire with black stripe, etc. Good luck. :) I hope this helps.
Blue1971FordTruck
with the truck at idle, with a voltage meter hooked up, it is a slow drain starts at like 14.2 then slowly drops
Aesop
Post by Aesop »
I did that once, changed everything and no help. In the end it was truly the last part. My ground wire to the engine from the battery was so greasy and dirty it did not make contact. Removed and cleaned terminal and block to bare metal and it worked. I don't know why it fixed it but it did.
67 F250 4x4
Blue1971FordTruck
that would piss me off if i went through everything and it was the damn block ground
