1970 F100 Project
- F100builder
Re: 1970 F100 Project
Thank you!
Patrick
'56 F100; Must.II IFS, 351W bored & stroked to 395c.i. 470hp/483ft-lbs., AOD, 4-link coilover 9" w/ 3.89's
'69 F100; 390, C6, Dana 60 w/ 4.10's
'70 F100; 'new' and latest project soon to have a built 390/C6 and 3.50 gears
To see more of my F100's: http://www.cardomain.com/id/lowfat56
Good job! And interesting info on the "hydro dipping".
- F100builder
Nothing crazy here...just finished up the framework for the fuel tank. I plan on using self-tapping screws to secure the tank to the frame. Then, I'm drilling 3 through-holes on each side and tacking some cage nuts to the top to secure it to the frame rails.
Patrick
- F100builder
I finally got around to the other cab corner...both corners were full of sand blasting sand which caused premature rust. Look carefully and you can see it pouring out the rust holes after I tapped it with a hammer. I was much more patient with the left side. Should take next to ZERO filler.
Patrick
- F100builder
I also did the filler neck delete today and finished up the '69 Mustang tank with a little paint and mounted it...
Patrick
- dantheman71
Looks good!
1972 Ford F-100
2002 Ford F-150
2002 Yamaha Raptor 660
Check out my NEW build thread: http://www.fordification.com/forum/view ... 93#p641993
2002 Ford F-150
- F100builder
Thank you!
Patrick
That's some great work there, Patrick!
- F100builder
Thanks Randy! I just have the antenna delete to do and then it's time for a little filler and LOTS of sanding...
Oh, I keep forgetting...I'm going to delete the stake pockets in the bed too.
Patrick
- SATURN5
Looking good!
Can you get a pic of the front of the tank and a measurement from the front of the tank to the crossmember. I've got a feeling the IRS subframe is going to be in the way..
Bob
68 F100 Flareside, CVIFS, Cobra IRS, DOHC, M122, MS3, T45, 4.10, Cobra brakes
84 Mustang SVO, B234F, HE351, Full Cobra spec suspension and brakes including IRS, T-tops
96 Mark VIII, Complete chassis bracing, 03 Cobra wheels, Maruader converter, built trans.
- tylerb43
Awesome work, Patrick! That tank just looks great, like it belongs there, nice job
- F100builder
Thank you! I'll try to get a pic tonight but I can already tell you that the measurement is 0". I placed it as far forward as I could.SATURN5 wrote:Looking good!
Thanks Tyler!tylerb43 wrote:Awesome work, Patrick! That tank just looks great, like it belongs there, nice job
Patrick
- damn_fool
Love your truck and your work on it so far. I'm in the process of gathering parts for mine now. When you buy the mustang fuel tank do you go with the kit with the new sending unit and filler parts or are you using left over parts from the pickups original system?
Jeremy
71 F100 that I haven't got to drive once yet. In pieces in the driveway =(
- F100builder
Thanks!damn_fool wrote:Love your truck and your work on it so far. I'm in the process of gathering parts for mine now. When you buy the mustang fuel tank do you go with the kit with the new sending unit and filler parts or are you using left over parts from the pickups original system?
http://www.ebay.com/itm/1969-Mustang-Co ... 6f&vxp=mtr
I then bought my stainless sending unit for around $35 w/ free shipping. It came with the o-ring and lock ring.
http://www.ebay.com/itm/69-Mustang-Gas- ... 54&vxp=mtr
The Mustang sending unit has the same resistance as our trucks so it will work with an original gauge. I bought aftermarket gauges but I stuck with the early Ford resistance so I could use the Mustang sending unit (72-10 ohms if I remember correctly). Classic Instruments offers fuel gauges for all makes and years as do several other gauge manufacturers.
As far as the rest of the system, I bought a preformed fuel line set for a '70 F100 (3 pieces) which came with the hard line for the in-cab tank that goes through the cab floor to the frame and the hard line that runs from that point up through the small boxed-in portion and ends in the area of the fuel pump. The 3rd piece is the hard line that runs from the fuel pump to the carb. Obviously, I won't be using the in-cab portion so I'll end up flaring the piece in the frame and connecting it to more hard line that will run on back to an electric pump and filters (pre-pump & post-pump) near the tank.
Patrick
- F100builder
I built up another dolly for the cab this last weekend and got it in place to continue the last of the metal work, bodywork, and hopefully get it and the doors primed and painted very soon. I have rebuild kits for the door hinges as well as all new rubber EVERYTHING for the cab, doors, and the rest of the interior. I want to get it sealed up and all the glass back in and mounted back to the frame for good by the time the cold weather hits.
Patrick
