1970 F100-Reverse lights not working, what do i check?
it is a 1970 ford f100/ 360 / c6 auto/ sat untouched for 13 years and motor and trans was recently rebuilt. just messing around, trying to get things to work. have replaced bulbs to no avail, any help will be appreciated
1970 ford f100
1998 chevy 1500
1963 chevy c-20
1962 gmc wrecker
1998 chevy 1500
1963 chevy c-20
1962 gmc wrecker
Re: 1970 F100-Reverse lights not working, what do i check?
You might check the neutral safety/reverse lights switch. It's on the steering column, just above the brake pedal.
Check the pin, it should slide L&R via the little arm thing.
Park in front on a glass door or have a helper watching, key on, slowly move the gear selector from park to neutral, they'll flash on if the switch is working.
There's a bit of adjustment on the switch, the mounting holes are slotted. Might be worth a try!
*edit*...Here's a photo of the switch on the column;
- bluef250
What have you done? Were the lights working before it sat?
1. Check bulbs and connections for continuity. Clean sockets of corrosion.
2. Switch should be on column. Check that it has not frozen (all gummed up) before replacing.
alrighty, thank you 72bahama the pic is very helpful and i will try that as soon as i can. And bluef250, i have replaced bulbs and checked with a test light and have got nothing to the bulb sockets. i really don't know if they were working or not before i got the truck
1970 ford f100
1998 chevy 1500
1963 chevy c-20
1962 gmc wrecker
1998 chevy 1500
1963 chevy c-20
1962 gmc wrecker
