I have a to do list for this truck that is long long long. i have neglected it due to my travels. i'm going to try to give it the attention it deserves.
to do list:
- replace the granatelli plug wire that broke, sleeve the wires and sleeve the boots with heat protectors and clean the spark plugs - even though i hate granatelli with every fiber within my body
- get tri y headers and full exhaust with a x pipe
- decide on a transmission - the nv4500 or a 6 speed - considering manuals only - suggestions welcome - even unique column manuals like the 6 speed from that japanese car, can't remember what it's called
- redo my seat belts, get some better shoulder strap seat belts or 5 points, anything to keep my tall ass in the bench
- redo my seat configuration, not sure what, should have head rests though, maybe a center storage compartment on a wide bench(that sounds nice), this seat configuration needs to be raised so that i can do speakers underneath the bench
- new steering column with tilt(this will be done at the same time as the transmission)
- vent the drums(get them drilled)
- replace power steering pump with saginaw and custom bracket (during transmission swap)
- add hydroboost (during transmission swap, can't decide if i should use my astro or my 75 grand marquis - the grand marquis bolt interface and the tail housing for the pushrod is waaaaaaaayyyyyyyy stupid design(but is a ford part so nostalgia))
- change to a electric choke quadrajet since my carburetor is being held together down the center by glue
- install the headliner trim i have (not going to restore them yet, just want them up there)
- get a passenger mirror to match my driver (the regular chrome oem ones, not the big window industrial mirrors)
- replace my rear view mirror
- change the oil - i'm going to do this in the next couple days. it rained alot here and the rain reminded me how ***** the hood to cowl weatherstripping is - my piece thats barely 2 years old is already bad and dumped water on my air cleaner which went down the carb into the engine - so yeah time to change the oil. i'm now parking my vehicle with a tarp over the engine every time i park.
so yeah i have alot to do. i've been working on employment to try and get some dough rolling in. keyenergy gave me a false lead so back to applying. might start welding and fabricating for a props company. been applying to shipyards and gas/oil fields and technician work in the mean time. things will come together in time.
and here is one pic
