Coil/Distributor Question
Corkwheats
Post by Corkwheats »
Hi Guys,
I'm installing an "old school" Mallory Dual Point Distributor (2755301) and a Mallory Voltmaster Mark II Coil in my F.E. in my 71 Truck. Do I also need to get some kind of in-line resistor to the coil? I spoke with the mechanic in town, and he said he thought I'd need one. Anyone ever heard of this?
Thanks,
Bob
71 Ranger XLT LB 2WD
Tilt Steering, West Coast Mirrors
390, 9.5-1 C.R., Holley 600, D2 Heads, C-6
Custom Grind Oregon Cam
Flotech Headers, 2.5" Duals w/H-Pipe
Re: Coil/Distributor Question
your truck already has a resistor wire from the ignition switch to the dist. if you need a resistor then the original wire will work fine. if not then you can bypass or cut and remo9ve the resistor part of the wire to get a full 12 volts. i would contact mallory to see what they say before i went cutting any wires on your truck though.
