The interior came out very nice and much quieter. I lined everything that I could with FatMat prior to carpeting and boy, what a difference. I still have some small holes in the firewall that I need to buy plugs for but overall, it is near done. There is a Cobra CB mounted under the seat and I hook up the mike with all the controls in it as needed. That way I don't have the CB showing when I don't need it. There is also a remote speaker mounted on the tranny hump. All wiring is under the carpet.
Also added a second battery with an isolator. This is to cover my camping needs in the camper shell. I use a CPAP breathing machine and I also may want to bring along my 12 volt fridge. I plan to have the camper built up this winter but in the mean time there is power to it now.
I also re-did the headliner. The original was getting worn and cracked and needed to be updated. My son in law and I decided to make a new one. We used the original as a pattern and fiberglassed it and then insulated between the headliner and the roof and covered the fiberglass with foam and cloth headliner material. It came out pretty nice for the little that we spent on it.
I am looking forward to getting the new shocks and replacing the spring bushings. I am also upgrading to H4 headlights with the relays and wiring. It never seems to end but I am enjoying the work.
Mikey
