Radio Antenna
davbell22602
Radio Antenna
Post by davbell22602 »
Were radio antenna's used on a 67 F100 2wd when the trucks made at Ford?
TNIceWolf
Re: Radio Antenna
Post by TNIceWolf »
Back then all vehicles were built with a radio as an option. Not everyone wanted or needed one especially in a work truck. Some were built with a radio and some not. So you would have to locate the factory info to see whether a particular vehicle was so equipped or not. Most if not all automotive radios of the time used a mast antenna.
Presently in the stable
1969 Ford F-350 DRW
bill69f100
Re: Radio Antenna
Post by bill69f100 »
My 69 came with an antenna. I found out it was bought for farm use in central Cal. Look at the cowling on the passenger side. If you don't have a rubber plug or a hole you didn't have that option. They're pretty easy to install.
Hawkrod
Re: Radio Antenna
Post by Hawkrod »
All factory radios used a mast antenna but not all trucks came with radios and antennas were not installed until the vehicle was at the dealership. Ford supplied the dealers with a template to drill the hole for the antenna and it was installed during dealer prep. Hawkrod
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
(3)68 Cougar XR7-G's
69 Cougar 428CJ 4 speed
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
http://www.supermotors.org/registry/veh ... 9&detail=1
