Ignition
R.Smith
Ignition
Post by R.Smith »
This morning when I went to start the 70F250CS, it fired fine but cut off, so I try again and nothing. No clicks or anything, so I jiggle the back of the ignition switch and it falls off in my hand! I replace the switch with a spare and still nothing. I check the fuse box and fuses with the meter, check the batt with the meter, tb the inline fuse coming off the cellonoid is good but, I have no power to the fuse box or switch. Any tips would help!!!
basketcase0302
Re: Ignition
Post by basketcase0302 »
Here's the wiring diagram for it that might help:
http://www.fordification.com/tech/wirin ... master.jpg
I would start at the post on the solenoid where the positive battery cable connects to, (the large terminal with the 1/2" nut).
Does anything electrical on the truck work? Headlights / horn or anything?
R.Smith
Re: Ignition
Post by R.Smith »
Nothing worked BUT, I swapped the cellonoid and now it works fine. Go figger. Thanks.
randyvines
Re: Ignition
Post by randyvines »
good thing about the solenoid switch, I have been through many ignition switches. The falling apart was too common i went through 4 in a matter of a year (life time warranties) at Oreilly's. When Oreilly's finally said that they didn't have any more I went to NAPA and got a OEM type it cost twice as much but has not failed in over a year.
