EZ Wiring Harness
bill69f100
Re: EZ Wiring Harness
Post by bill69f100 »
I put mine in last year. It is the 22 circuit harness. It comes from both.I blew my 50A fuse and the guage said I was over charging. I was still driving when it happened. I checked and had 14.56 which on mine was normal. I did get the schematic for my 69' which helped alot. The one they give you is for GM. :pout: It took me about 37 hours to get mine in. Soldering is the best way to go. I used rubber grommits in the firewall and flexloomed the rest. I just started merging a harness from a 05' CVPI into the truck.
usmcjones1988
Post by usmcjones1988 »
does anyone know what wire goes to the I post on the starter solenoid for the EZ wire harness?
F100builder
Post by F100builder »
I have the EZ harness and there is NO wire on the "I" terminal of the solenoid.
Patrick
'56 F100; Must.II IFS, 351W bored & stroked to 395c.i. 470hp/483ft-lbs., AOD, 4-link coilover 9" w/ 3.89's
'69 F100; 390, C6, Dana 60 w/ 4.10's
'70 F100; 'new' and latest project soon to have a built 390/C6 and 3.50 gears
To see more of my F100's: http://www.cardomain.com/id/lowfat56
Thunderfoot
Post by Thunderfoot »
For the "I" terminal on the Starter Solenoid it is just a wire from there "I terminal" to the (+) of the coil... it is not in the harness so to speak, so wouldn't be in the EZ harness... This wire from the Starter Solenoid is to give the ignition coil full 12V during cranking to help start the engine when it is cold, it is activated by the Starter Solenoid when the "S" starter wire is activated and shuts off the same way...
usmcjones1988
does anyone know where the other end of the dome light wire is I can only find the one wire that goes to the light it self not the switch one
Thunderfoot
usmcjones1988 wrote:does anyone know where the other end of the dome light wire is I can only find the one wire that goes to the light it self not the switch one
There is only one wire going to the Dome Light and it is connected inline with the door switches and to the light switch. See diagram here http://www.fordification.com/tech/wirin ... ycargo.jpg
usmcjones1988
i tried wire up my alternator and voltage regulator the why and EZ manual said to and im not getting anything at the battery, has this happened to anyone else?
