replacement original radios
bjde0b
Post by bjde0b »
will any of the ford/philco radios work if they are from 67-72 era?
Re: replacement original radios
alot of radios will fit. even the 73-79 will fit if you get the right one. but the rear brace bolt may be in a different spot. so you may have to make a new brace.
mk
Post by mk »
68-72 are definitely direct interchange, though they came in two slightly different housing styles.
mike
~Will Rogers
Mercury truck ID thread:
Ford truck model history:
Using dentside fender liners:
Matchbox diecast bumps:
bumpsidetom
Post by bumpsidetom »
the '67 is smaller than a '68. The '67 is a one year only.
