Apparently I have a pretty bad ground somewhere on the truck that just started showing up. I have disconnected the negative battery cable and put my voltmeter on the negative battery post and the disconnected negative battery cable and it shows a full 12v. As I understand it, the meter should read 0 while doing this.
I have an aftermarket volt meter in the cab and, up until now, it always showed a nice steady 14v while the truck was running. Now, it jumps about 2v at a time up and down and the volt meter is reading closer to 9-10v when the truck is running. It looks like the ground comes and goes instead of being a steady draw. Like when the turn signal is on.
The battery is only 6 months old, and the alternator is about 5 years old. A few days ago I put a new voltage regulator on and it did not help. I plan on having the alternator and battery tested tomorrow. But.....the ground is still there.
When I had the negative cable disconnected, I pulled the fuses one at a time on that little fuse panel under the dash above the gas and brake pedals. The 12v draw was still there. Then, I unplugged all wiring connections that I could find under the dash one at a time and the 12v draw was still present.
So, how can I go about narrowing down my search to find the ground. I'm guessing there is a wire that has gotten the covering rubbed off and is resting on something metal. Occasionally, everything works OK and the voltmeter show 14v when the truck is running.
The truck does have the factory overdrive unit (that does not work
Sorry for the super long post, but I wanted to give as much info as I could. So, what is the best way to narrow down my search?
Cooter
