67 only cargo switch
i saw on on ebay a few months ago. i didnt bid for it. because i didnt have the correct 67 switch wiring. does anyone have a picture of the plug that goes on the back of the switch? what does it look like. i know what the 68-72 switch plug looks like. but not the 67 only switch. or is it the same? or is it a wiper switch type of two pronged plug? same as wiper switch? the reason i aks is that i found a similar swithc but i cant see the prongs on the back. if i get the switch i want to be able to make a wire that looks original. even thoughi could use bubble gum and bailing wire. i want original.
dolinick
Re: 67 only cargo switch
Post by dolinick »
I have one from a '67. I have the wire and the cargo lamp also.
2003 7.3L F250
1968 F500 Utility Truck
what does the wire look like? can you get a picture of it. there may have even been a mid year change for all i know. soem of the 67 may have used the 68 and up switch and plug i have no idea for sure.
dolinick
Post by dolinick »
I don't have it with me. It is out at my cabin. If/when I go out there I'll look at it and take photos. :(
2003 7.3L F250
thanks.
