Cool headlights
Hemp8709
Cool headlights
Post by Hemp8709 »
Anybody have angel eye headlights,projectors,hid etc? I am have a few in mind but, want to see if anybody else has installed them and how they like em. Includes some pics!
Hemp8709
Re: Cool headlights
Post by Hemp8709 »
I couldnt wait. I went ahead and bought these. 8)
Thunderfoot
Re: Cool headlights
Post by Thunderfoot »
Be sure that you run new wire from relays to power them, the stock light switch/wiring wont handle them...
Hemp8709
Re: Cool headlights
Post by Hemp8709 »
Thanks thunderfoot! I will look into that. :D
TX69F100
Re: Cool headlights
Post by TX69F100 »
Doesn't someone on the forum sell pre-fabbed wiring harnesses for running headlights off of relays from the battery?
Brent
1969 F100 Ranger 390/C6 <--- Build thread
Hemp8709
Re: Cool headlights
Post by Hemp8709 »
I personally don't know. Does anybody have a set of after market headlights? would like to see what they look like and how they installed them. Any help is appreciated!
TX69F100
Re: Cool headlights
Post by TX69F100 »
Try PMing 390Nut if you'd like to ask him about the harnesses.
Also, check out these threads:
http://www.fordification.com/forum/view ... ng#p193821
http://www.fordification.com/forum/view ... &sk=t&sd=a
I don't have any info regarding the appearance of aftermarket headlights.
Brent
marz68
Re: Cool headlights
Post by marz68 »
Hemp8709 wrote:Anybody have angel eye headlights,projectors,hid etc? I am have a few in mind but, want to see if anybody else has installed them and how they like em. Includes some pics!
I saw the first ones on a freightliner the other day and they looked good!!!
Do you have any pics of yours instaled?
Hemp8709
Re: Cool headlights
Post by Hemp8709 »
I am actually figuring that out now. Looking on this site trying to figure out how to do it. Someone mentioned that i need to run new wires bc the switch and old wires wont support them. When i get em installed I will for sure pst em. Just got em in the other day.
ezernut9mm
Re: Cool headlights
Post by ezernut9mm »
390nut makes the relay harnesses from time to time. i think he is thinking about making them again.
Hemp8709
Re: Cool headlights
Post by Hemp8709 »
ezernut9mm wrote:390nut makes the relay harnesses from time to time. i think he is thinking about making them again.
Yea, i pm'ed him. Said check back later. Kinda want to put em in asap.
STROKER69
Re: Cool headlights
Post by STROKER69 »
Okay, if 390nut is not able to help you right now try lmc, they sell a harness like I think you need, or are wanting.
Hemp8709
Re: Cool headlights
Post by Hemp8709 »
So in order for my headlights to properly work I need to run new wire to the relay? if so what guage? was thinking 14 ga.
390Nut
Re: Cool headlights
Post by 390Nut »
There is no relay to run the wire to, hence the kit I make (or the one LMC sells). It bypasses all the switches/wiring in your truck for power to the lights, taking it from the battery and straight to the bulbs. Much less resistance in the wiring that way, and you get higher voltage. 14 gauge would be fine, but you still need a relay, for each circuit. (high-low)
Do those have a seperate lead/terminal for the ring lights? If they draw from the same terminal as the headlight bulbs you are definitily going to want a relay inline for each circuit.
My harness threads (both of them) got deleted, they had all the details of what the harness does, how and why.
My harness is a lot cleaner install than the one from LMC, made to fit this truck style (dentsides too). Currently awaiting info on fitment into the Slicks, so I've been holding off on offering them for the time being.
Paul
`69 F100 390 4spd driver
Pipes71 did once say, "bumps and bikes.. what a great combo!" :thup:
Hemp8709
Re: Cool headlights
Post by Hemp8709 »
390Nut wrote:There is no relay to run the wire to, hence the kit I make (or the one LMC sells). It bypasses all the switches/wiring in your truck for power to the lights, taking it from the battery and straight to the bulbs. Much less resistance in the wiring that way, and you get higher voltage. 14 gauge would be fine, but you still need a relay, for each circuit. (high-low)
Thanks for the info Paul. i just orded the light harnes from lmc. I couldnt wait :D . Here is a pic of how they hook up.
