is there a way to test a used TSS without complete install?
- kilog55
Re: is there a way to test a used TSS without complete install?
ok i have voltage in the open circuit
electrical is always backwards
1968 F250 Ranger 2wd 472ci TH400 Caddy powered.
1979 F250 Ranger 4X4 400ci T18
anyone need a 60x24x24 flatbed semi toolbox?
my gallery - http://www.fordification.com/galleries/ ... ?cat=10437
oh man dont confuse me. i can never remember which is which.
- 70_F100
So, that means you have voltage on one side of the switch when the pedal is up, but none when the pedal is depressed, right?
That's not an oil leak
- kilog55
yes on two diff switches, one is new the other is out of my 79 and it works in the 79 as far as i know.
- kilog55
okie dokie, every single light is now working but i need a new TSS that little clip that sandwiches it all together broke, but i have functional brake lights now. wasnt get any power to the one side of the wire, with the brakes off i had voltage, but with them applied i had nothing so i rewired it and surprisingly i have brake lights now.
The switch is still available from your Ford dealer, part number DOTZ-13341-B. Be sure to take that part number with you, as their computers don't go back that far and they can't look it up by vehicle. Probably wise to replace both horn carbons as well while you have wheel off. I replaced mine last year, details here http://www.fordification.com/forum/view ... a&start=15 .
