Are gauges interchangeable year to year?
Madsen1970F100
Post by Madsen1970F100 »
I have 1971 F100 donor and removed the instrument panel to get the temp gauge to install in my 1970 project. Right away there are differences..... :?
the 71 donor panel had idiot lights for oil pressure and alternator. The connector on the rear was smaller than on my 1970.
My 1970 panel has all the gauges, no idiot lights. the connector is larger. makes sense so far..... :thup:
the temp gauge has longer mounting screws, but installed without any issue. I tried to put my old temp gauge in the donor instrument panel and the mounting screws were too short. NO big deal, its a donor truck,right?
Well, now I have temp gauge that works :hd: However, it reads rather warm, needle sticks on the 'M' pointing towards overheating. :roll: NOTE: Since I just got it running after rebuild, I only have water running in the system now and no antifreeze/coolant.
Question is.....is the higher temp reading a result of different resistance within the gaugue itself? OR is the mounting screws only a product of the casing it was in originally? In short, is there any electrical differnce between the temp gauge in a 1971 with idiot lights vs. a 1970 with full gauges?
Eric
Richmond, Virgina
1970 F100 project?
1971 F100 donor
Re: Are gauges interchangeable year to year?
the length of the botls on back wont change anything i wouldnt think. the gauge readings can be changed by adjusting the ipvr on back of the cluster. but i would only do the adjustign if the fuel tank is not readign correctly.
Madsen1970F100
what should a working gauge register for resistance if you hooked to a meter?
Eric
Richmond, Virgina
1970 F100 project?
1971 F100 donor
