ignition switch connector
69f-100
Post by 69f-100 »
does anyone know if this ignition switch wire connector (number 16) will work on my 69? http://www.lmctruck.com/icatalog/fb/full.aspx?Page=79 i cant seem to find a listing for one for the 69. let me know what ya think.
Mancar1
Re: ignition switch connector
Post by Mancar1 »
Seems to look like the one on my 68. I believe the 68 and 69 are the same. There are 3 different ones. One that fits 67, one for 68-70, and one for 71-72. When you order make sure you tell them it is for the 68/69 years. You may try to find a boneyard one to pull. The diagram looks like LMC is saying that is for 67-72. :hmm: I'm not sure this makes sense to me, and I wrote it. :lol: :doh: Took a closer look at #16 and it says it is for 70-72. Seems like you could get it and you would have to get the ignition switch to fit.
Someone else will jump in on this with more beans in the noggen than me hopefully. :lol:
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
no its not the same as the 68/69 ignition switch. the 67 switch is also different than the 68/69 switch. that switch plug is for 70-72 trucks only. however you can change your switch and the plug to a 70-72 switch and plug.
the 68/69 switch has bullet connector on the switch. the 70-72 has spade connectors on the switch. 67 has a spade connector sort of. it is one mian bolt on terminal with foru spade conncetors and one of the spade connectors is all by itself. as well the 67 plug wont work on any other trucks.
69f-100
Post by 69f-100 »
but i could just buy the switch and plug for the 70-72 and that would work correct? if thats is the case i will just do that then.
yes as i was saying you can buy the 70-72 switch and the plug they have.
69f-100
Post by 69f-100 »
ok thanks forman i really appreceiate the help...
