OK, got it running today so must have
most of electrical figured out
However, gauges worked at first but not later and just wondering if these resistors or capacitors have anything to do with it. I also know I probably do not have all my ground wires hooked in but thought that was mostly for lights. Have the short one on back of engine to the firewall connected. Wondering what these two things are and also this "extra" wire that comes out the wiring harness near the voltage regulator. I am thinking it should be a ground? its the connection with the star-like center.
Told you I'd be back with stupid questions.......I have looked at the wiring diagrams and just too stupid to figure this out so asking for a little help.
BTW, got it running and fairly smooth though the timing appears to be quite retarded (if I am using that term correctly) should the timing light hit it at TDC or is it ok to be off like 20 degrees??
Thanks!!
