ez wiring harness
- 69f-100
ez wiring harness
hey guys i was thinking about buying an ez wiring harness for my 69 f100 but thier are like 4 different options on the site. i'm not sure which one i would need. maybe someone can point me in the right direction.
- 69f-100
Re: ez wiring harness
go here fordman http://ezwiring.com/ that way you can see what im talking about rathter than me trying to explain it.
- seattle67
I would suggest at least getting the "mini 20", but if I was buying it I would spend the extra 20 bucks and get the "EZ 21.
Dan
in my opinion mini 20 more matches what we have in our trucks. mini 21 doesnt have a dome light listed. i alos emailed them complaining of how they have the options listed randoly like that in both the 20 and 21 packages.
im am in the process of installing the EZ 21. its got every option on my ranger plus some upgrades that i will add in the future eg. elec windows and a/c. i havent ran into any problems yet and the total cost with shipping was about 200.
Matt
"I have as much authority as the Pope, I just don't have as many people who believe it." George Carlin
'68 F100 Ranger LWB 2wd 360ci C6
'75 Chevy 3/4 ton Flat Bed 350ci 4x4
'03 Yamaha Road Star Warrior 102ci
fordman wrote:in my opinion mini 20 more matches what we have in our trucks. mini 21 doesnt have a dome light listed. i alos emailed them complaining of how they have the options listed randoly like that in both the 20 and 21 packages.
69f-100
From what I'm reading they have the 2 "Mini" ones and 2 Standard ones and each has its own circuit sizes/options. The MINI they are referring to the Size of the blade fuses they are using in the fuse block, these are those really small blade fuses where as there Standard ones are the normal size blade fuses. Having the smaller mini blade fuses will make the fuse block smaller and as such makes it easier to mount in a small space like an old hot rod coupe, for our trucks I would not be concerned about that and my fingers have a hard enough time with the regular blade fuses and those mini's are tiny-small
If your not going to ever add any options to your truck like power windows and such and just want to upgrade the wire and get a couple more things fuse by them selves I would just use there "12 standard" but for the extra $15 the "EZ 21" will give you some extra fused circuits in the fuse box to use for other things.
Myself I would use the EZ 21 Standard as I want to add P/W at some point
- 69f-100
alright guys i'm still listening to oppinions but with what i have so far, i think i will be going with the ez 21 considering i'm going to be rewiring the hole truck. thanks for your info guys it really helps.
