fuel guage works sometimes
hey i need some help with this.i have a new sending unit and sometimes my fuel guage works and sometimes it dont.any thoughts .thank you in advance.
- basketcase0302
Re: fuel guage works sometimes
Check this out if might help:
http://www.fordification.com/tech/fuel- ... -units.htm
Mine was acting up a month or so ago, it was the float. Price for repair...$3.00 float! Priceless!
it has a new sending unit and float.
I'm with Fordman, ground connection maybe.
Troy
- basketcase0302
Does it have dual tanks with the dual sender switch? If so, I'd look at the wiring on the switch like Fordman and towtrucker suggested.
Are you getting voltage to the sending unit?
Maybe also trace the fuse for it, (mine was kinda' rusted-had to clean up the contacts with a small wire brush).
no its just stock tank behind the seat.i do get power to the sending unit.if i ground out the power wire the guage reads full
- Fordman5
Believe or not, mine does the same thing and when it does i wiggle the ign key a little one way or the other and it starts to work. Funniest thing.
Proud owner of a 1967 Ford F100
that switch is worn out.Fordman5 wrote:Believe or not, mine does the same thing and when it does i wiggle the ign key a little one way or the other and it starts to work. Funniest thing.
- basketcase0302
I would ohm out (check the resistance) of the sending unit. I can't remember what the value (number) should be, but I believe it's in the above link to the "fuel tank tech".71highboy on Fri Jan 28, 2011 7:45 am
it worked all day yesterday so i will see what happens today
