What size Batteries does this thing take?
Re: What size Batteries does this thing take?
i think a poor ground could help it loose power and not want to run at full capicity. on our truck that havent been modified. the only frame to body ground i can think of is from the lower valance to the frame. and that is probably only strong enough to run lights. of course the bed is grounded to the frame and the tail lights are grounded to the bed. as well the headlights and parkign lights are grounded to the core support. and then the body is grounded to the engine. and the battery is grounded to the battery.
- tanusfarms
makes sense, I do know that my ground at the lower valance is gone, so it looks like I am going to be buying a new cable to use as ground.
- Bumpside Collector
I read though that and there is some good stuff there. I was just going off what I have seen with boat batteries. I guess not everything you think you know you really know!Thunderfoot wrote:That is FALSE Lead acid batteries have no memory, draining them down all the way will kill them faster then anything. Deep Cycle batteries are built using the same basic materials as the regular batteries but have thicker plates to handle greater discharging (bigger reserves) without killing them. Look at the info posted in the link that Fordman posted above all this info is in there.Bumpside Collector wrote:From what I understand about deep cycle batteries I don't think I'd use one for starting. They are designed to be drawn down almost all the way and then recharged. I don't think the battery would last as long in the truck. If you wanted something dedicated to the winch then I'd say to get one.
CHEESE?!?
Running:
2012 Ford Focus SE hatchback
2007 F-150 XLT Supercrew 4.6 Auto
1972 F-350 Flatbed 360 2V 4 speed
Not Running:
1967 F-100 Ranger Short Bed
1970 F-100 Ranger Long Bed
1972 F-100 Ranger XLT long Bed
1972 F-350 Really long dump flatbed parts truck
1981 F-250 Custom Long Bed (Parting out now)
No problemBumpside Collector wrote:I read though that and there is some good stuff there. I was just going off what I have seen with boat batteries. I guess not everything you think you know you really know!Thunderfoot wrote:That is FALSE Lead acid batteries have no memory, draining them down all the way will kill them faster then anything. Deep Cycle batteries are built using the same basic materials as the regular batteries but have thicker plates to handle greater discharging (bigger reserves) without killing them. Look at the info posted in the link that Fordman posted above all this info is in there.Bumpside Collector wrote:From what I understand about deep cycle batteries I don't think I'd use one for starting. They are designed to be drawn down almost all the way and then recharged. I don't think the battery would last as long in the truck. If you wanted something dedicated to the winch then I'd say to get one.Does that make sense?!?
