Truck dead in the water
EMCustoms
Post by EMCustoms »
I have been working on my brother-inlaws 73 F100 for the past 6 months getting it road ready, I replaced the following items; ignition switch, coil, starter relay, battery. It is weeks between the time I work on the truck since I live 100 miles away and never had any problems getting it started. The last time I worked on it I fixed all of the lights then parked it. When I went back the next time the truck acted like it had a dead battery so I checked the battery and is still good, it seems there is no power getting to anything past the starter relay; the lights and horn won't even work. I am new to this truck and have looked the the wiring diagrams but am lost at were to start, any ideas will be helpful.
Hemmi06
Re: Truck dead in the water
Post by Hemmi06 »
Check the cab power wire. (Black with Yellow stripe) with the work on the light may have shorted. There is a fusable link in there that could have died. Also how is the Volatage Regulator?
1971 F250 Camper Special
360cu with RV cam and 4v Carb
EMCustoms
Post by EMCustoms »
The voltage regulator looked original so that was my next thing to replace. I wil also have to check the power wire. Thanks for the info.
check the connection on the starter relay where the positive battery cable hooks up. it could have lost contact for some reason. that is where i would start anyway. yo udo know how to cross the large and small terminals to start the engine?
