Who is making these now?
I have an older non-maintenance free one, it is suffering from disuse and lack of a trickle charger. It was made by "new castle battery" or something like that. Shortly there after I believe Turbo Start bought them and began making the maintenance free ones. I think Turbo Start went out of business?
Anyway, who is making them now, I see year one and Mustangs Unlimited seem to have them. They are very expensive, I don't really mind the money as long as they are at least as good as your normal high quality MF Battery (Interstate, Exide, DieHard, Delco, Motorcraft).
Reproduction Autolite Batteries.
- DuckRyder
- Mancar1
Re: Reproduction Autolite Batteries.
New Castle Battery Mfg. Co. as far as I know.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
- DuckRyder
Funny, it looks like New Castle leads to Turbo Start which leads to Axion Power, but I can't find the Autolite on their site...
- Mancar1
Search: Who makes reproduction Autolite Batteries. Or: New Castle reproduction Autolite Batteries. Hope this helps.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
- DuckRyder
Did that, most of those hits are old (some as old as 2002).Mancar1 wrote:Search: Who makes reproduction Autolite Batteries. Or: New Castle reproduction Autolite Batteries. Hope this helps.
Maybe NewCastle does still make them, but you would think that they would put them on their website...
I actually had pretty good luck with this one but the new Maint-Free ones are apparently full AGM, that should be good...
- Mancar1
Found this: Antique Auto Battery has the group 24FA Reproduction Autolite Batteries for, ouch, $240. I will e-mail you the #. I called them and they are still around. Hope this helps you in your quest.
I am going with a Optima when my Napa Battery goes, if not sooner. Had one in my 81 Ford truck and it lasted for 11 years. I use a Optima Deep cycl marine to run the alarm system at the cemetery matenance buildings. They are $$$$, but dependable, with a lot of crank.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
- Mancar1
Antique Auto Battery not only sells Reproduction Autolite Batteries for our trucks. They also make them.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
