Dome light
68FORDJBM
Dome light
Post by 68FORDJBM »
Next on the list is the dome light. I don't have power to the dome light wiring but the cargo light works. I know starting out that the door switches are not hooked up. Do I need the door switches or can the circut be hooked up another way - can the dome light be switched on inside the cab? It a 68 ranger. Thanks in advance.
FORDification
Site & Forum Admin
Site & Forum Admin
Re: Dome light
Post by FORDification »
The dome light can be turned on by simply turning the headlight switch all the way to the left.
Here's the wiring diagram you need to get everything else hooked up right.
68FORDJBM
Re: Dome light
Post by 68FORDJBM »
Thank You! This should get me started
68FORDJBM
Re: Dome light
Post by 68FORDJBM »
Well, I have power all the way to the bulb and the switch works fine so I must have the bad or wrong bulb. The bulb filament doesn't look like it is bad and I've tested two different bulb housings with two different bulbs.
68FORDJBM
Re: Dome light
Post by 68FORDJBM »
Mystery solved: the dome light housing needs to be installed and grounded:) Everything works fine now:)
