I have no brake lights!
ericknight
Post by ericknight »
1970 F100, have tail lights & rear blinkers but no brake lights. I disconnected plug at brake pedal switch and tested it with a test light, it has power going to it. Bypassed the switch with a jumper wire and they still didn't come on. Tested all fuses and they are good. Hazard works on the front but not the back, and they stop when you press the pedal. Any ideas? Is there a brake light relay somewhere?
Re: I have no brake lights!
i just looked at the 70 master diagram. the power comes out of the fuse box to the hazard flasher then down to the brake light switch. from there it goes into the turn signal switch. from the turn signal switch that wire 810A goes to the hazard flasher switch. my bet is the turn signal switch is going or gone bad. wiggle it. and see if the lights come on.
ericknight
I unplugged the turn signal switch from the harness and tested wires with my test light. One is hot all the time, I guess it's for the horn. One is hot when I depress the brake pedal, so it is getting power to at least the turn signal switch. Three of the wires flash when I turn on the hazzard switch. How hard is it to replace the turn signal switch, and where can I get a new one?
the one that is hot all the time isnt the horn. if you press the brake pedal and the one wire gets hot then the switch may be good. and i tcould be in something else. i can't think properly right now. i need to eat something. i'll look at it later.
ok i checked again. i am thinking since the switch has power going out of it then it has to be a bad wire beteeen the tss and the rear brake light wires.
ericknight
Replaced turn signal switch and everything works now. Still available from Ford dealer, $66.32. I already knew the part number, DOTZ-13341-B, and that's what they looked up on their computer. I wanted to verify that it was the correct part number, so I told them to look it up for a 1970 F100, but their computer only goes back to 1980. So I would have been out of luck had I not already knew the part number.Image
is that a date on the box? 01-31-07. maybe when it was made? or the box was made?
ericknight
Looks like a date to me. I ordered it at a dealership in Rome, GA and they got it from Memphis, TN. Here's one on ebay with a different date http://cgi.ebay.com/ebaymotors/NOS-FORD ... ccessories
if it is a date then ford has been making these up until atleast 2001 from the box on the auction.
quantumleap
Post by quantumleap »
what tool is needed to remove the pins from the connecter on the tss harness?
picture? price? place to get one?
Daniel--67' reg cab black shortbed/fe/4spd/ford 9
BobbyFord
Post by BobbyFord »
quantumleap wrote:what tool is needed to remove the pins from the connecter on the tss harness?
One like this: http://www.automotive-diagnostic-tools. ... -56500.htm
There are several types for the different types of terminals. I have a few types if you need to borrow one.
quantumleap
you have one for the harness goin into the steering column?
the one bobby posted is fo rmultipule plugs and wire sizes. it should work. i use a pick.
quantumleap
so you just push them out without trying to destroy the harness housing?
i use the pick to depress the little tabs that hold them in while i put pulling pressure from behind. i pull the wire slightly as i pick at the tabs. and they slide right out when the two tabs are closed enough to slide back through.
