MSD Blaster 2 with Duraspark
70_F100
Post by 70_F100 »
I've done the search, and I've looked at all of the wiring diagrams, and I can't find the answer to my question. :? Either that, or I'm just overlooking the obvious (good possibility) :doh:
I'm getting ready to install a Duraspark setup in my 70 F100 w/360, and I'm planning on using the MSD Blaster 2 coil with the correct Ford Duraspark horseshoe connector (MSD P/N 8205). :thup:
My question is, can this coil handle full 12V, or do I need to put a ballast resistor in the coil + wire? Alternately, does the factory resistance wire provide the correct voltage? :hmm:
Any help with this is appreciated.
BobbyFord
Re: MSD Blaster 2 with Duraspark
Post by BobbyFord »
I'm getting conflicting information on my MSD paperwork. I eliminated the resistor wire in my Duraspark/MSD set up.
70_F100
Post by 70_F100 »
Thanks, BobbyFord.
That's along the lines of what I've been finding, so I'm hoping someone here who has done the conversion successfully can give me a clarification.
I know yours is a new build, so I'm guessing you haven't put a lot of miles on your truck since installation.
BobbyFord
Post by BobbyFord »
Well one thing that I can tell you for sure is that when using an MSD 6AL box instead of the regular Duraspark module (with a Duraspark distributor and MSD Blaster2 coil) the coil is powered from a straight 12V source from the MSD 6AL box.
It doesn't matter what module you are using. MSD wiring diagrams use 12V to power the Blaster2 coil when running a Duraspark distributor.
