Battery Drain??
Battery Drain??
My battery(new)has been going dead.I noticed(finally)today that my tail lights are on all the time!!!!Is this a short or a grounding problem??How do I troubleshoot/fix??I have no electrical experience.HELP!
Re: Battery Drain??
Re: Battery Drain??
I have the same problem. Currently I have the pedal strapped up to the steering wheel to keep it of the switch,preventing battery drain. Right now I have bigger fish to fry, replaceing all brakes and lines. Before she gets put back into service, I will have to address the issue.
Good luck to ya, I will be keep up w/ this thread.
1970 F100 Custom
Re: Battery Drain??
Thanks guys!As usual,you are right on target.So,I ordered a new switch from LMC.
Now,how do I replace the switch when it comes in?It's a 1970 F-100 auto trans.I can't figure out how the switch mounts to the brake pedal and I don't want to break anything trying.........
Re: Battery Drain??
unplug the wiring from the switch and unscrew the switch from the pedal bracket. unless it has been repaired using a couple of nuts. then unscrew the nuts and slide it out of the bracket.
Re: Battery Drain??
Thanks.Much appreciated !!!! I think its stock as there were no screws/nuts/bolts around the switch unit.
- BRUTUS_T_HOG
Re: Battery Drain??
all my local auto parts stores have replacement switches for less than $10. i just replaced onecapeclassics wrote:Thanks guys!As usual,you are right on target.So,I ordered a new switch from LMC.
ASE Certified Technician
