Instrument cluster lighting.
- 1968Ranger
Ok, I preface this by saying Im bad with the electrical end of things.
My instrument cluster appears to be working-Speedo-fuel-temp- all functioning properly.
At night the backlighting will not illuminate. Ben and I pulled the cluster and checked the five bulbs. All appear in good shape. I do not own a meter to test nor would I know how to use one. (yes Im an idoit)
Does anyone have a suggestion on how to isolate the issue and fix.
The fuse box for the truck has all new fuses.
Thanks in advance.
Mike and Ben
Thanks in advance.
Mike and Ben
Re: Instrument cluster lighting.
does the light swithc have a broken coil wire thing ? that coudl make them not work at all.
- 1968Ranger
BROKEN COIL WIRE THINGY???????????? Please expound and I will investigate.
inside the ceramic white thing is a coil of wire. if it is broken then the lights wont work. this is a common problem.
- 1968Ranger
Is that the large round White piece behind the dash thats part of the ON/OFF light switch?
- 1968Ranger
Thank you
Give me some daylight and Ill pull and replace it.
Go Heels
Mike
Go Heels
Mike
- flyboy2610
It's called a rheostat.
http://www.fordification.com/forum/view ... at#p413046
Red Green
you'd better be right.
Red Green
i couldnt think of that word for nothing earlier. and i was so tired and sick feeling i didnt even want to do a search for one word. thanks john.
If yours looks anything like this, needless to say it's DOA.
- 1968Ranger
Thanks Keith. I hope to fix tomorrow.
No more laughing at me
- flyboy2610
Headlight switches aren't too expensive. You local parts store should have one.
Red Green
Red Green
