Backup lights
- michael69
Backup lights
What is the best way to make backup lights work after changing from a 3 speed on column to an automatic column. It is a 73 - 75 column don't have a neutral saftey switch on it. I have a 77 c6 and it does not have a switch on it either. Will one of the later transmission mount switches work and does it just plug in to the plug that was on the 3 speed column?
Michael69
'69 Ranger 'F-100 2WD SWB 351W C6 AUTO
1985 CJ 7 jeep w/35s
1967 SS Chevelle 502 4 speed
2003 Heritage softail w/110 cubic inch screamin eagle kit
Re: Backup lights
You will want to use the trans mounted switch for Neutral safety and backup lights. The plug will not just plug into the old truck plug, you will have to do some adapting.
I would connect it at the jumper plug under the dash where both these wires are at.
Re: Backup lights
I'm interested in this topic as well.. I THINK my truck originally came as a column shift manual, and the PO put in an automatic trans + column. No safety switch on the column, and no switch on the trans. Do I just need the neutral safety switch?
Patrick
Patrick
Chevrolet
1969 F100 4X4 Highboy 390 3sp
1969 F100 SWB 2wd Auto 351w
1972 F100 Ranger XLT 302 Auto
http://mrsnicks.blogspot.com
Re: Backup lights
yes just as thuderfoot said. get the transmission mounted nss. to make it all work right.
Re: Backup lights
Anyone got a part number or a link to the part or something to get my search started?
Patrick
Patrick
Chevrolet
Re: Backup lights
heres a ebay search. i didnt look all the way through it. http://shop.ebay.com/items/__ford-neutr ... 286.c0.m19
this is very similar to the one you will be looking at getting. it will look very similar to this one but the one you want will or should have two moutning holes instead of one. http://cgi.ebay.com/ebaymotors/79-80-81 ... ccessories
Re: Backup lights
here is another similar one. its for a c3 transmission thoguht and its an auction for 3 of them in one shot. http://cgi.ebay.com/ebaymotors/ws/eBayI ... MEWAX%3AIT
