I have tried using our resources first, but it has made me even more confused...
I am trying to figure out the configuration of the dash cluster connection... the wiring diagram we have here has more wires addressed than what I actually have... and there numbered instead of color coded.
I have the following (and have figured a few of them out)
left side:
Green/blk trace - hi-lo lite
white/blu trace - right turn
black - ground
blue/red trace - ?
lt blue/red trace -connected to the one above.. still ?
tan/white trace - left turn
red - ?
yellow - ?
other side:
white/red tracer - ?
Orange - fuel
Purple - key hot
Red/white trace - ?
Anyhow, I havent figured which is headlight switched (tried w/test light, might be a fuse blown). Need to find volts, oil and water temp in the ones with "?" marks.
Any help would be appreciated.
Benji
1970 dash cluster wiring-Ughhhh
hmmm - does a twin turbo'd, EFI 331 stroker belong in a F100?
TIRES are front: Uniroyal P255/60-15s and rear: Uniroyal P275/60-15s
http://www.fordification.com/galleries/ ... by&uid=464
Re: 1970 dash cluster wiring-Ughhhh
forgot... all this is a question because I am installing an aftermarket set of dolphin guages.
- knightfire83
Base / Tracer
Green / Black -- High_Low beam indicator
White / Blue --Right turn signal
Black -- Ground
Blue / Red and Lt.Blue / Red -- Dash lights
Tan / White (should be Green / White) -- Left turn signal
Red -- Starting motor relay batt. terminal to amp gauge batt. terminal
Yellow -- Alternator output A terminal to amp gauge load terminal
White / Red -- Oil pressure sender
Orange -- Fuel sender
Violet -- Ignition switch
Red / White -- Temperature sender
Sources:
http://www.fordification.com/board/Ford ... -chart.gif
http://www.fordification.com/images/sch ... _quick.jpg
http://www.fordification.com/images/sch ... s81-85.jpg
Good Luck !!
Black -- Ground
Sources:
Good Luck !!
1970 Ford F250 4x4 ~ Sold.
