70-72 cluster in 69 f100
i found a 70-72 f100...it has a good instrument cluster in it and was wondering if it will work in my 69 f100 without having to mod anything at all??
Re: 70-72 cluster in 69 f100
I think there is a section on here that shows the differences in the panels mainly being wiring. I would try looking at that.
Troy
- Lar4t9r
1969 did not have the printed circuit board but 70-72 did. 1970 "Only" is different than other printed circuit boards. The plugs will not work stock from the '69 ino the later years, and '70 won't work stock on later years. You would need to do some re-wiring.cjroddam wrote:i found a 70-72 f100...it has a good instrument cluster in it and was wondering if it will work in my 69 f100 without having to mod anything at all??
Here is the location of info on this site to check out the cluster diferences:
http://www.fordification.com/67-72ID.htm
Laurence (Proud owner of 1969 Ford F-100 and 1970 GTO)
