Igniton Switch Wiring
I just bought a new wiring harness for my 70 becuase I messed it up bad! But anyways my 70 harness and the new one has Yellow,Purple,Green-Black,Red-Blue,And A Redish Pink Wire. But My New Harness Has A Red-Green And My 70 Has A Light Blue What Do They Do? Should I Just Join Them Or Leave Them Un-Hooked?
"Flyin High On Caffine And Copenhagen" R.I.P Chris LeDoux
60 Mercury Comet
65 Ford Econoline
72 Ford F100 on 79 4x4 SWB frame
77 Ford F250 "lowboy" 4x4
09 Harley Xl1200c
60 Mercury Comet
65 Ford Econoline
09 Harley Xl1200c
Re: Igniton Switch Wiring
harnesses can be for many trucks. atleast four different ones i would think. there would be with and without guages and automatic vs standard. that is 4. what harness didi you have before and what harness do you have now? your truck had auto and guages ? and the parts truck had? that sounds like a truck with standar trans and guages. i have a switch cut off here htat has the same colors. it came out of a 69.
what is the part number on the harness? and doesnt everything just plug in?
The truck I took it out of was I believe an automatic with gauges and its eitheer a 70,71,72 I can't tel because no grille shell at all but I found 70 grille inserts behind the seat. And the truck it's going into is a 70 auto without gauges. I took all the wiring out of the junkyard and also the instrument cluster. I'm planning on just taking my hole harness out and putting this one in place of it. Also the junkyard truck had air.
60 Mercury Comet
65 Ford Econoline
09 Harley Xl1200c
60 Mercury Comet
65 Ford Econoline
09 Harley Xl1200c
there should be a small wrap of paper near the largest part of the harness with a part number on it. if you can tell me that number and i can look at my harnesses and tell you whats what on it. they are uncut.
I looked for a part number but there isn't any I guess the rats or something in the junkyard must have got to it.
60 Mercury Comet
65 Ford Econoline
09 Harley Xl1200c
60 Mercury Comet
65 Ford Econoline
09 Harley Xl1200c
- Hawkrod
Automatic and standard trans used the same wiring harness. The only differnces in main harness' are guages versus non guages, A/C or Non A/C, engine size, and whether or not it had overdrive. There are 9 different harness' for a 1970 but otherwise identical trucks with a stick or an automatic use the same harness. Hawkrodfordman wrote:harnesses can be for many trucks. atleast four different ones i would think. there would be with and without guages and automatic vs standard. that is 4. what harness didi you have before and what harness do you have now? your truck had auto and guages ? and the parts truck had? that sounds like a truck with standar trans and guages. i have a switch cut off here htat has the same colors. it came out of a 69.
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
(3)68 Cougar XR7-G's
69 Cougar 428CJ 4 speed
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
http://www.supermotors.org/registry/veh ... 9&detail=1
59 Tbird 430
60 Lincoln
(2)62 Tbirds
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
the reason i was saying that is because of the three on a tree wire length to the bottom of the column to hook up the backup light switch. i would guess that the np435 would have the same kind of deal going on with it too. since the np435 backup light switch is suppose to be on the transmission.
fordtruck as far as the wires. check the wiring diagrams. you will need the complete cab and front clip wiring to get a matching set that works without having to cut and splice.
- Hawkrod
The backup switch wiring is a seperate part that plugs into a small plug on the inner fender where the main harness comes out. All trucks have the plug there. The stick shift trucks all have a plug under the dash for a neutral safety switch too, that is how they make them fit stick or automatic. Hawkrodfordman wrote:the reason i was saying that is because of the three on a tree wire length to the bottom of the column to hook up the backup light switch. i would guess that the np435 would have the same kind of deal going on with it too. since the np435 backup light switch is suppose to be on the transmission.
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
59 Tbird 430
60 Lincoln
(2)62 Tbirds
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
i know that plug your talking about coming out of the cab. i do have one here that doesnt have that plug on it for some reason it just goes straight down to the 3 speed column. i have never seeem one like it before. i have also never had another 3 speed truck. i
I joined all the matching colors today and in the morning I'll take a picture of the last two I'm un shure about. I'm shure the truck the harness came out of is auot because it had the plug for my neutral saftey switch.
60 Mercury Comet
65 Ford Econoline
09 Harley Xl1200c
60 Mercury Comet
65 Ford Econoline
09 Harley Xl1200c
- Hawkrod
A stick shift truck also has a plug for the neutral safety switch as I noted so there is no way to know if the harnes came from a stick ofr an auto. Look under the hood, you will also find a plug for a stick shift back up switch on the drivers inner fender. They have that too even in anautomatic truck. The only exceptions are OD trucks and cetain engine sizes. HawkrodFordTruck wrote:I joined all the matching colors today and in the morning I'll take a picture of the last two I'm un shure about. I'm shure the truck the harness came out of is auot because it had the plug for my neutral saftey switch.
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
59 Tbird 430
60 Lincoln
(2)62 Tbirds
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
Here's The Two Wires. One Comes Off The Big Yellow Wire And The Other Comes Off Of The Big Black With Green Stripe.
60 Mercury Comet
65 Ford Econoline
09 Harley Xl1200c
60 Mercury Comet
65 Ford Econoline
09 Harley Xl1200c
