I have been following 1970F100's Horn thread because mine isn't working either.
A couple of questions...
Should the horns sound if I take a ground and a positve lead directly from the battery grounding the horn body and touching the prong where the connector goes?
How does one check to see if the horn relay itself is working?
I'm probably going to order a new one.
Maybe, I could get one at the local parts house. Do other years fit?
When checking the horn button circuit, all I need to do is push the horn carbon with a grounded test light to see if that circuit is working ???
I'll probably run into some more questions before this is done...
It looks like I might be upgrading my fuse panel to the blade style fuses in the near future...
Yesterday, my whole system was dead unil I jiggled the wires going into the fuse panel.. then the power came back on... not a good sign...
KaptnKA
