I have been trying to troubleshoot my wiper motor. I picked up a new motor but before I pull the dash totally apart I wanted to slide by and get some opinions.
The wires that went to the washer pump were disconnected so I fixed that problem and ended up with rust red sludge all over the windshield
Well I know that the washer function works but the wipers still wont fire up..
Just to make sure I covered all my bases I swapped the fuse with a new one and still no wipers.
OK so I start to trace wires and find that the Orange/white has 12 volt..
I checked the red,black,blue,white and none had any voltage what so ever.
So to try and isolate between switch and motor. I figure I would send some voltage down the red,white,blue... I assumed that black is my ground. I get a spark from the blue and the white and no motion to the motor..
I then assumed that the red is hot the black is ground the blue and white are my 2 speeds.
Nothing...
SO now I figure its time to slip in here and ask the gang...
And another question... ALL my inside and outside lights are surging with the lobe of the motor and get dim on a lower RPM and get brighter when the RPM is higher...
I assume that this is the sign of a weak altinator?
