seat belt fastener
seat belt fastener
What size is the "star" bit that holds seat belts to the mounting point? Does it vary over the years, or from make to make?
Former owner of 70 LB SportCustom and a 71 SB SportCustom. Looking for a replacement bump!
- 71 LONG BED
re: seat belt fastener
The "star" is called a Torx and I think it is a T30 or maybe a T25. I had mine out a few times but can't remember the exact size. I just know which one to grab. If you are buying one from a parts store I'm sure they will let you bring it back if it doesn't fit.
And no, I don't believe it varies.
John Member #1549
Funny you should ask that, 'cause my Torx bit is sitting right here by my computer, stripped out. I ruined it a while back trying to remove the seatbelts, and then brought it home so I could try to find a replacement.
It's a T47.
It's a T47.
Thanks. I was at Sears the other day and saw some torx bits, with the black finish metal like they were for impacts. They were pricey, but I probably ought to go pick up a set.
It's better to have it and not need it than need it and not have it.
- 71 LONG BED
Re: re: seat belt fastener
WOW, sorry about that. I don't know why I was thinking 25-30!!!! I wasn't even close.FORDification wrote:It's a T47.
John Member #1549
Sears has 45, then it skips to 50. Guess I need to look elsewhere.
- 460 crew
I have the Craftsman set and the 50 on my set fits the seatbelts perfectly, Just can't get them to brake loose.
- 71 LONG BED
I used an inpact gun.
John Member #1549
