Need help with wiring new turn signal switch
Charlie67f100
Post by Charlie67f100 »
Hello everyone I just bought a new turn signal switch from dennis carpenter but my wires are different color on my old ones old one is a seven wire harness colors are yellow with black stripe, dark green ,a navy blue, green with white stripes, blue with yellow stripe, white with light blue stripe, and a red from black stripe. The truck is a 67 f100 with a 390 was a 352 fe.
Charlie67f100
Re: Need help with wiring new turn signal switch
If anyone can help me with this one I would be greatful.
sargentrs
Post by sargentrs »
About all I can suggest is to go to the wiring diagrams and map your wires to another diagrams with colors that match your new switch.
http://www.fordification.com/tech/schematics_h.htm Looks like DC's calling out for '69-'72 so I'd start with the '69 diagram as being closest to yours. You'll probably have wires left over, no side marker lights on a '67. Just make sure you insulate any loose wires so they don't ground out on you.
Charlie67f100
I will check the diagrams I got the one that it calls for on the 67 f100 same number of wires just difference in color I was hoping someone had got one of these replacement switches like me and could give me some pointers
