Aftermarket cd player
Lone Ranger
Post by Lone Ranger »
When my key is in the off position with the key out my CD player continues to play. I brought power from the positive side of the starter solenoid. I also grounded the radio straight to the battery( when not grounded to the battery the CD player would get very hot). Is my ignition switch faulty?
Every time I go to start the truck it's dead too. I can jump it and run it awhile but turning on the lights kills it and I have to jump it again. Not sure if these issues are related. Anyone else ever have these issues?
Kyle
Nitekruizer
Re: Aftermarket cd player
Post by Nitekruizer »
The best place to get power for an aftermarket CD, Cassette or AM/FM Radio would be to use the fused power wire to the original factory radio. Otherwise, I would connect the CD Player's power wire to a switched terminal in the truck's fuse box. There should be a switched and unswitched terminal in the fuse box. If your CD Player has a clock, you would connect the clock/memory wire to the unswitched terminal of the fuse box. Make sure that the CD player's power wires have in-line fuses.
Lone Ranger
I have my aftermarket radio all wired now but now I have a question about the under dash speaker. I assumed I could hook up front left and front right to this dash speaker. When I do this however the sound gets fuzzy. I have rear left and right going to door speakers. I hate to just have one side of the radio going to the dash speaker.
Does the under dash speaker have the ability to play stereo left and right?
Do I have to get a dash speaker that has two small speakers in it?
Kyle
Nitekruizer
That's good to hear I'm glad you got it working. You can't use a single speaker for left and right. You will need a dual voice coil speaker. You also may be able to cut a piece of plexiglass, metal or particle board/plywood to fit the dash speaker hole and mount a pair of 3 1/2" co-axial speakers where the original factory speaker was. Something like this;
https://www.carid.com/ic/custom-autosou ... 1001_1.jpg
Lone Ranger
Thanks nightkruiser. Did the factory radio radio setup not have stereo sound? My old truck with stock radio sounded great.... But only got AM
Kyle
