turn signal fuse keeps blowing
mindblown
Post by mindblown »
my turn signal fuse keeps blowing on my 1968 ford f100 every time i turn the key. I can not find the problem for the life of me. it doesnt matter if i try to use the signals or not all i do know is if i unplug the turn signal harness at the bottom of the steering column it doesnt blow. please help
cep62
Re: turn signal fuse keeps blowing
Post by cep62 »
:wel:
Welcome to the site.
Get a sealed beam headlight and two jumper wires.
hook the light up to the fuse terminal , so basicly the head lamp is the fuse and will prevent your wiring from melting.
If you have a short the lamp will light, then you can track down the short and repair it
My guess is in the steering coloumn or the rear taillight harness where people hack in trailer wiring.
keep us posted .
66f250cs
Post by 66f250cs »
Sounds like you have a short to ground with one of the turn signal switch wires possibly inside the steering column.
I would unplug all of the wires from the terminal block at the end of the turn signal switch wires as if you were going to replace the turn signal switch. Take your VOM and set to resistance, clip one wire from the vom at one end of a known good fuse that is in the fuse box and place the other wire from the vom at the other end of the fuse. With a good fuse, you should read infinity. Now start plugging in wires one at a time into the correct port of the terminal block. Watch your vom for action. If the fuse blows with the last wire you inserted, you know that that is "bad" wire. Kinda hard to explain good luck.
66 F250 camper special
69 F250 Explorer
85 Mustang GT with 1900 original miles
92 Festiva with 538,000 original miles
86 E350 extended WB van
Various IH & JD tractors (5)
TT & XT500 mc's (6)
BSA, Triumph's and twenty Yamaha two strokes
