Factory Air
68rookie
Factory Air
Post by 68rookie »
My truck came with original factory air and is currently not working. Before I go to the trouble of getting it up and running was just curious to know from those of you that have it, is it any good? Does it do a good job, do you need a special radiator etc??????
My goal in life is to be as good a person as my dog already thinks I am!
1968 F-100 Longbed 390/C6
Mach428
Re: Factory Air
Post by Mach428 »
I rebuilt a factory AC unit and installed in my 69. It works great as there isn't much space to cool.
If your truck came with factory air, it should already have the heavy- duty radiator and fan. My truck did not have AC but it did have the HD cooling. I replaced the 5-blade fan with a 6.
68rookie
Re: Factory Air
Post by 68rookie »
The radiator that originaly came with the truck was shot so I replaced it with a generic that fit from Advanced Auto. What Radiator should I have if I going to get the A/C running?
