wiring diagram 69 F250 camper special
claudius
Post by claudius »
hello , can any body help me find a wiring diagram for my pick up, its a 1969 F 250 with a 360 cu inch none of the dash board instrument work and my alterntor and regulator are in place but b4 i connect them I like to make shure all is wire correctly. thank you and happy new year, claudius
acemang
re: wiring diagram 69 F250 camper special
Post by acemang »
I would check your instrument cluster voltage regulator. That usually is the culprit for guages not working. Good Luck
Ford-get about it
wt4speed#2
Post by wt4speed#2 »
The wiring diagram Keith has in the tech section worked well on my '69 it's good info
Tony B
Tony B.Image
DFW Area
"Someday...
I hope you to get the chance,
to live like you are dying"
Member#'s 236 & 403
Úlf the Comedy Sidekick
'69 F-100 "Stepper"(currently in a bigillion pieces )
wt's ride
thebucket
claudius
Post by claudius »
thank you guys,
I work it with what I found on keith's cite, that help put some order to all that wiring mess, great trick was to print the diagram on 9 pages and stick it on the wall, never the less now the ammeter work but to show that the system is soon as I turn the keys to ignition the needle go to discharch??? I use the 1970 diagram model it seemse to be the closest to the 69. and of course the alternator and regulator are new!!!???
