only starts if you jump the solenoid but wait..
InsaneScout
Post by InsaneScout »
Gents,
I have a 73 F100 w/302 Automatic tranny. Here is the problem, I have no power to the headlights or dash lights, it wont start unless I jump the solenoid. I just bought it this way last week. It has a new solenoid and ignition switch. I have looked at the fusible link that goes from the solenoid to the alternator and somehow I just don't think that's it. but I don't really know what else to do. I was thinking it might be the neutral safety switch but that wouldn't have anything to do with my headlights and dashlights not working.
Please help.
Busboy
Re: only starts if you jump the solenoid but wait..
Post by Busboy »
You definitely have a power supply to the ignition switch issue . Your going to have to get a test light or a voltmeter and verify that the fusible link or wire is not open. A wiring diagram is your best friend here.
1967 F-100 4x4 custom cab.
InsaneScout
Thank you for the info, this is the one and only thing that I hoped it wasn't. I hate chasing wires.
I will start tomorrow.
Thanks.
Aurelio Landeros
Post by Aurelio Landeros »
InsaneScout wrote:Gents,
Please help.
i have a similar problem i can start the truck but i cant turn it off coil gets super hod headlights wont turn on
this orange wire is what my coil is hooked up to this is a 71 factory harness and im not sure that's the right wire
Aurelio Landeros
1970 f100 240 I6 3.9L 1bl carb 4 speed light duty
wheeble
Post by wheeble »
Years ago I had a similar issue with my 69, it was a short in the headlight dip switch on the floor. Cheap fix if that is part of your problem.
1971 F100, Balanced and blueprinted 390. Rebuilt AOD transmission and drive line. Repainted back to factory colors (seafoam lower, boxwood upper).
